| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Question: How do you know how much to step down your motors (are there formulas)? Are there instances when you don't have to step down your motors? I am building a router and driving it with belts on the x and y axis and I will be using unipolar steppers (700-1000 oz-in). |
| Thats the $100.- question. The most reliable way I know is when you take a Identical machine that is aready build and running with the same motors and test its performance then make a decision about your own machine based on that. O.K. maybe thats a little hard to come by for us one of a kind mechanics. Do you have the Torque curve characteristics of your motors it would be a good start to know what kinds of useful speeds those motors will be getting at and what torque will be left at that speed. A better understanding of the loads required on your machine would help too. Weight and methode of guides. Then maybe we can find some similar machines and go from there. Another methode is to find out a peticular load for cutting a peticular material at a peticular feedrate. The configure your drive to provide this and a little extra for good messure. Then accept whatever rapids this setup will give you. Good Luck |
If the ratio is higher than this a reduction is required. Fortunately, the inertia can be reduced by square of the reduction. e.g. a 10:1 reduction reduces the inertia by 100. Al
| Does anyone know of a controller board for synchronized stepper motors | Yellowbeard | Stepper Motors and Drives | 2 | 04-03-2005 11:06 PM |
| Looking for controller board for synchronized stepper motors | Yellowbeard | General Electronics Discussion | 0 | 04-02-2005 08:50 AM |
| Stepper Motors | kellogs72 | Stepper Motors and Drives | 1 | 11-29-2004 07:27 PM |
| Help On Stepping Motors | sdigeso | DIY-CNC Router Table Machines | 1 | 04-07-2004 03:51 PM |
