Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-05-2009, 11:02 PM
Delanoman is on a distinguished road
HELP Power supply broken... Bridge rectifier smokes... Coil heats up.
I just wanna know what going on with my power supply. Earlier today I had it up and running no problem. Then I plugged it in again and the bridge rectifier started to smoke up. With no wires going out of the power supply it still smokes up. I am curious if I can fixed this unit by just replacing the bridge rectifier. Thanks
http://cgi.ebay.com/38V-400W-CNC-Mil...QQcmdZViewItem
Old 04-05-2009, 11:09 PM
Al_The_Man's Avatar
Probably shorted bridge, pick up a higher current one for replacement, did you have correct fusing in place?
Old 04-05-2009, 11:15 PM
No I don't have any fuses protecting my power supply at all, didn't think I'd need them. I only have them for my motor controllers and my steppers. How should I set fuses up for my power supply?
Old 04-06-2009, 10:19 PM
Al_The_Man's Avatar
There should be correct fusing, in the primary at least of your transformer.
Also optional in the secondary leads to the bridge.
[IMG] code is Off
Bridge Rectifier Location cbarsh Bridgeport and Hardinge Mills 5 07-10-2008 11:08 PM
How hard is it to figure out the size of cap and bridge rectifier for a power supply journeyonline General Electronics Discussion 10 04-04-2007 04:31 PM
Bridge rectifier go poof blfinche Hobbycnc (Products) 7 10-18-2006 07:11 AM
Switch Mode Rectifier as power supply andy_ck87028 Stepper Motors and Drives 20 04-29-2006 10:17 PM
bridge rectifier osdhillon General Electronics Discussion 4 12-30-2005 09:24 AM
