Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-29-2009, 06:17 PM
patvan2020 is on a distinguished road
DRIP FEEDING TO NC80 PRO
Hi
I have a Heller BZH 07 with a Siemins NC 80 pro control on it. Does anyone know if this machine has Drip feed functionality and if so how to do it. I know how to do this on Fanuc but this control is like none I have ever used before.
Kind Regards
Patrick
Old 04-09-2009, 08:54 AM
justtx is on a distinguished road
No one can sit here and tell you if you have that capability on your specific control or not. From my understanding, it's typically an option that is sold with the machine by the manufacturer. I have seen some controls of a certain model have the ability to DNC/Dripfeed, and others of the same model not be able to. You're best bet is to contact the machine builder and give them the serial number and ask them directly, unless you have the shipment invoice direct from the builder, which is should list all options.
Someone might be able to tell you if those controls support it, but not if your specific one was given the option.
[IMG] code is Off
Drip Feeding widgitmaster Polls 26 01-28-2011 02:02 PM
Drip Feeding Andre' B General CAM Discussion 3 10-27-2008 12:40 PM
drip feeding vtc-41 scottn Mazak, Mitsubishi, Mazatrol 1 11-08-2007 06:52 AM
Drip feeding your V2XT weyland Bridgeport and Hardinge Mills 4 03-01-2007 09:53 AM
drip feeding problem yoya Machine Problems, Solutions , Wireless DNC, serial port 31 07-07-2006 12:33 PM
