Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-28-2009, 05:22 AM
BMTS is on a distinguished road
Exclamation Gould Gettys 410 Serial Coms
I am trying to recover a machine that has a Gould Gettys 410 Position Controller (circa 1988) communicating with a Xycom 4810ER via Serial Communication out of the Programmer Port on the Gould. The Xycom Terminal lost its memory. I need to set up the Com Protocols in the Xycom to match the Gould. Does anyone know the correct Protocols for the 410? I have a 480 Programmer that if I disconnect the Serial Cable from the Xycom, I simply plug in the 480 and communication is established.
Any Help is greatly appreciated since there are so many permutations for the Port Settings
[IMG] code is Off
Gettys 360 amp questions dave3431 Servo Motors and Drives 3 03-19-2008 08:56 AM
Gould motor brushes needed Tom Curran Servo Motors and Drives 2 06-21-2007 06:42 AM
Gould servos--maintenance question Tom Curran Tree 3 06-07-2007 10:45 AM
gettys motor don_harby Servo Motors and Drives 2 02-15-2007 06:08 PM
gould gettys servo motors kollander Servo Motors and Drives 5 12-25-2006 12:14 PM
