Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-11-2009, 06:34 AM
japco43 is on a distinguished road
Question y home moves over
I am running a program on our router, and after a while the Y axis seems to have moved over closer to home. the profile is good, but since I have multiple parts in the jig, one side gets tighter, and one side gets looser. We just had the router retrofit with camsoft cnc plus. Any help will be appreciated.
[IMG] code is Off
Need Help!- Getting some bad moves. Stampede BobCad-Cam 1 09-26-2008 07:47 PM
DRO moves but not machine? cncwhiz Mach Mill 9 09-18-2008 12:35 PM
Moves on command IQChallenged Mach Mill 4 05-09-2008 08:10 PM
Help tring to cut hex using c x moves DryRun G-Code Programing 7 09-30-2007 05:15 AM
Changing Z moves Davidimurray Post Processors for MC 5 02-10-2007 01:59 PM
