| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Having problems with tapping a hole. Using a 1-14 3 flute bottoming tap. trying to tap a casting about an 1 1/4. Problem is the machine is thrown into alarm almost to the bottom of the hole. When I get the tap out, it is packed with shavings. I thought maybe a spiral flute might help so I ordered one today. Should be here tommorow. If this don't work, does anybody got anymore suggestions? Maybe tap halfway, pull out and then finish tapping? Thanks, Shawn
__________________ Shawn |
| Shawn, What material is it? If it's cast iron, then a straight flute tap would be okay, maybe a plug version instead of bottoming, though. What kind of machine? Does it do repeat rigid tapping? I would think that it would be good to take a couple of passes to do the hole, so that you could get some new lube on the tap as it progresses farther down. Have you considered thread milling? This is what I would recommend for the cleanest looking threads, and far less brute force is required to drive a thread mill than a tap. If its a blind hole, a spiral flute is generally the correct choice for normal tapping.
| Tapping head any good? | kong | General Metalwork Discussion | 6 | 04-19-2005 03:49 PM |
| tapping 303 stainless | bobcor | General Metalwork Discussion | 8 | 03-28-2005 04:58 PM |
| tapping chrome plated shaft? | sixpence | General Metalwork Discussion | 8 | 01-29-2005 05:23 PM |
| Rigid tapping on a BPT TC1G w DX32 control | machintek | Bridgeport and Hardinge Mills | 0 | 01-01-2005 07:06 PM |
| Tapping | MPE racing | General CAM Discussion | 9 | 11-06-2004 12:42 PM |
