| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
We are having some problems with the ATC on a 2000 Amera Seiki VAS 3M with a Fanuc O-MD controller. When we received the machine, it was missing 3 pots in the tool changing magazine. While running a program with a couple of tool changes, the machine was trying to put a tool in a place where there was no pot. I hit the E-stop while the arm was at the spindle. I was able to rotate the arm back to a zero position and clear the ATC error, but I am now getting a “Magazine not oriented” message. If I try to rotate the magazine, the machine doesn’t pull up the pot before it tries to rotate the magazine, which causes a bind. We have turned the machine on and off a couple of times, turned the air on and off a couple of times, the sensors seem to be functioning properly, and we have rotated the magazine back and forth to a couple of different positions to try to clear the message, but to no avail. I have read through what machine manual says to do, but it still doesn’t seem to be working right. |
I have a few years ago the same problem with a mazak cnc and the problem are: the position sensor works intermitent, not allways send the signal but, the light of the sensor allways working, check with a multimeter the voltaje output of the sensor, some times the output is bad but the light of the sensor works good. |
| BOSS8 "+Z OVERFLOW" error message | jonny | Bridgeport and Hardinge Mills | 11 | 05-29-2008 04:12 AM |
| V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" | rfdoyle | Bridgeport and Hardinge Mills | 4 | 10-08-2007 03:35 PM |
| Fanuc 11M alarm message | Moparmatty | Machine Problems, Solutions , Wireless DNC, serial port | 12 | 08-06-2007 09:32 PM |
| Fanuc 11m error message. improper number of axis | kmcmillen571 | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 04-01-2007 07:14 PM |
| "Services For-Hire/Wanted" message board | samualt | Forum Questions or Problems | 4 | 03-16-2004 08:29 PM |
