Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-01-2009, 06:54 PM
Delanoman is on a distinguished road
No motion from project using KL4030 driver
Stepper is a FL57STH56-3006B, 6 lead stepper motor, 3.0 amps, 1.8, 2.3v
Driver is a KL4030
5vdc Power source (driver and breakout board)
38v dc Power source ( steppers)
The stepper wires are:
Black}Green
white-Common
Red}Blue
Yellow-Common
Also i did a test to find that:
Blue is coil 1
Black is coil 2
Red in coil 3
Teal is coil 4
I connected the motor to my driver with:
Yellow&White- +38v
Black- A+
Teal- A-
Red- B+
Blue- B-
Does anyone know is this is correct at all?
I have been unsuccessful at generating any movement from my steppers. All that happens with i plug in my setup is the motor seizes up (which i think is fine). I have been trying to get movement using a simple beta program called "Stepster". Is there any other free software that might resolve my problems? Any help is appreciated- thanks.
Old 02-01-2009, 07:46 PM
ViperTX is on a distinguished road
Well, as I see it you have 8 coils with 2 commons.
The Teal is also the green?
In Bipolar (parallel) the common of the common (white) should go to A- and Black/Green should go to A+.
Don't you have a datasheet for the steppers?
38 VDC should only be applied to the V++ of the driver and not the driver coils.
I use Mach3. I hope that helps.
Paul
The other common (yellow) should go to B- and Red/Blue should go to B+.
Old 02-01-2009, 07:53 PM
Well that certainly is a different way from which i wired it up. I do have a data sheet, i found it off the internet at http://www.akcesoria.cnc.info.pl/pli...owe.pdf?t=2239 page 25. I don't find it extremely helpful tho because it doesn't make it clear as day for me. Thanks
Also where i wrote Black}Green, I didn't mean that the wire is colored black and green, I was trying to show a description of the wiring diagram i have off of the net.
such as:
Black
Yellow MOTOR
Green
Red White Blue
Old 02-01-2009, 08:13 PM
resetting the wire leads didn't fix the problem, I've still only got holding torque. Is there a trial of Mach3 or something else that will allow me to test my setup without a full purchase?
Old 02-01-2009, 08:17 PM
Yes, you can download Mach3, I believe from ArtSoft.com or net....forget which do a Google.
Do you have the outputs on your BOB enabled?
Old 02-01-2009, 08:43 PM
Okay, that's better.
Yellow goes to A- and Blk & Green go to A+.
White goes to B- and Red & Blue go to B+.
If that doesn't work just switch them out.....all the A's go to B's and the B's go to A's.
Paul
Are the BOB's outputs enabled?
Old 02-01-2009, 09:09 PM
I am not sure if the BOB outputs are enabled. On the breakout board i did put wires going from the Xlimit and the E stop into the Common that a circuit would be made there, but that had no effect on my dilemma.
Old 02-01-2009, 09:19 PM
I don't know which BOB you have, but generally +5 VDC goes to the enable, then to E-Stop (Normally Closed) and the E-Stop's input pin on the BOB.
Generally all the limit switches are wired serially, and I believe most BOBs use a separate input pin for the limit switches. One side of the limit switches has +5VDC and the other side goes to the input pin.
Which BOB do you have?
Paul
Old 02-01-2009, 09:55 PM
I am fairly certain i am using the KL-DB25 Breakout
Board From keling
Old 02-01-2009, 11:38 PM
I got it working, The problem had to do with the Mach 3 setup. After about 20 different searches and countless hours through these forums i found an article with a link to a document by Keling showing how to properly configure Mach3 for my application.
I get movement now wired at
A+ BLACK
A- GREEN
B+ RED
B- BLUE
the two common wires are not in use. My NEXT question is what will the difference be if i use them (torque,Speed), and how should they be put in?
[IMG] code is Off
Newbie- Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver? joprinz General Electronics Discussion 4 04-28-2011 03:57 AM
Need Help!- Selecting motors that won't damage my driver (Applied Motion 2035) MoparJon Stepper Motors and Drives 2 09-13-2008 06:57 PM
CNCZone Driver Group Project aubrey Group Projects 8 01-27-2008 08:55 AM
single axis driver and a b.o.b.,or multi-axis driver board .xXACEXx. Stepper Motors and Drives 3 07-02-2007 11:13 PM
Paid consultant needed to provide email/phone support for my stepper driver project. jerryrigge Employment Opportunity 5 09-28-2004 09:23 PM
