Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 12-02-2004, 07:42 PM
cncshawn is on a distinguished road
Reamer Question?
Any chance of a reamer handling .025"? Of course this is only .0125" on each side. I know that is a big cut, I have always went with no more than .010". Any opinions? Oh ya, cutting a soft casting. Thanks.
Shawn
Old 12-02-2004, 08:27 PM
HuFlungDung's Avatar
Moderator
The more you cut, the more likely the reamer will cut oversize, and chips may score the hole. If you "peck-ream" with complete retractions, you may be able to prevent scoring the hole. I like your first impression of .010. That's comfortable, if the reamer is in the 1/4" range on up.
Old 12-03-2004, 04:07 AM
Thanks, that is what I figured, maybe I can try to peck and see.
Shawn
Old 12-07-2004, 10:37 AM
E-Stop is on a distinguished road
Also depends on the size of the reamer. Get up in the 1.250-1.500 range and .025 stock removal is the norm.
[IMG] code is Off
Extremely basic machining question. touser General Metalwork Discussion 9 06-19-2005 12:51 AM
Question about power supplies dowling177 General Electronics Discussion 1 01-28-2005 07:01 AM
Adjustable Reamer Question Joe_CNC General Metalwork Discussion 6 11-07-2004 08:27 AM
Just a question about plunge milling. Machine1 Hard and High Speed Machining 4 01-28-2004 08:36 PM
HF lathe question rs1300 General Metal Working Machines 0 01-19-2004 11:22 AM
