| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
| Hello, I have a old General Electric 7542 control connected to a Warner and Swasey 1-SC lathe that I use mainly for one project part, this old control has worked fine till reciently, the problem is in the offests, it has thumwheel offsets that has a "X" axis problem, whenever any offset is called up the X amount moved is correct. BUT the direction is wrong. SO x-.020 will move in .020 but when the offset is cleared it still moves in .020 instead of moving back to where it belongs, even if a x+.020 is entered in the offset it still moves x- and clears x- therefor the distance is correct but not the direction in the X axis.... BUt the Z axis offsets works fine BUT and any axis movement in MDI wont work... I cleaned and reseated all the logic boards and checked all fuzes,, i feel its a bad board in the logic stack but I dont know which one... is anyone any idea how i can fix this problem... I have books and diagrams on the control but my Knowledge of electronics is not in depth.... Any help is greatly Appreciated.. Dave. |
Have you had any luck with the offset problem. Try the CAP2 board its one of the 1/2 height boards, when I had that problem it effected both axis the same way. middle row of cards, 9 from the right. Good luck, Mike |
The CAP-2 board calculates the incremental move when programming in absolute G90 mode. It usually calculates the wrong size move when it failes. Tool offsets involve the TO-1, SD121 boards and some IF241 boards. Do all 4, 8, 12 or 16 tool offsets do the same thing? If it is only four bad offsets it may be the SD121 board associated with those four. If all offsets are bad it could be the IF241 board in slot 1-14 although it seems that the IF board in that slot would also make the Z offsets bad. The TO-1 board is the tool offset board, it is always suspect with an offset problem. IF241 boards are all alike, you can trade one with another but know where you put it because something else won't work after a trade. You can also trade SD121 boards but there is only one TO-1. And you might just fix it by unplugging, wiping the contacts and replugging the above boards. These controls are known for connection problems. John |
| G-Code to DXF | WayneHill | OpenSource Software | 200 | 04-22-2012 09:51 PM |
| Visual Basic Controller Project | dwwright | Visual Basic | 29 | 02-14-2011 01:24 PM |
| CNC Glossary | CNCadmin | CNCzone Club House | 17 | 03-09-2008 03:08 PM |
| DC speed control problem | Swede | General Electronics Discussion | 6 | 02-07-2005 09:06 PM |
| Fanuc 18it Control problem | Wjman | Machine Problems, Solutions , Wireless DNC, serial port | 6 | 11-19-2003 12:41 AM |
