Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-19-2003, 04:46 PM
Buried's Avatar
Buried is on a distinguished road
Anilam 3300MK
Anybody else running one of these controllers? I have 2 here, one of which likes to decide for me whether or not my arc centers in my posted programs are "logical" or not and change them on me if it doesn't think the arc center is logical. I've screwed around with the setup to no avail...I did find the Maximum Arc Correction setting, but this seems to set the tolorence for how often the "Warning Arc adjusted beyond maximum ...." error messege comes up and not the actual maximum amount to correct. I've also screwed around with limiting my maximum and minimum arc radii posted to my programs, also to no avail. It seems this Anilam has a mind of it's own when it comes to "logical arc centers" .I would like to turn this arc "correction" off completely since it's "corrections" arent really corrections at all, they gouge my parts, but I can't seem to be able to find where I might do this in either the operator or builder steup of the controller.
Also, this seems to happen more frequently on 180-360 degree arcs ......
What I find most odd is that the other Anilam 3300MK we have does not this.
You can't live forever, but can you be dead forever.....
Old 05-20-2003, 01:46 AM
HuFlungDung's Avatar
Moderator
If your controllers are identical models, and one is acting up, I would suspect some kind of hardware malfunction, such as a failing circuit board. I have no idea what your controller looks like inside, though, so you'd best get a real service technician on the phone for help.
If the controller tells you that there is an error, is this just "after the fact" when it does an in-position check when the arc is completed, and then attempts to correct it, or does it halt with an error before it does the faulty arc?
Old 05-20-2003, 08:49 AM
Buried's Avatar
It halts with an error before it does the faulty arc (I'm pretty sure....) . I have set the Maximum Arc Correction to 0.000, thinking at first this would stop it from correcting arcs, when all it did was stop the error messeges and I'm still gouging parts every now and then.
They are identical models, though one (the one that does the gouging) was bought about 2 years after the first and has a faster processer and Im sure upgraded versions of whatever operating software its running.
Old 05-30-2003, 12:01 PM
Buried's Avatar
bump
...anyone?
Old 05-30-2003, 03:18 PM
Moderator
I'd suggest you post a sample of the actual nc code you are using, in a circumstance where your controller gives you the fault. Preferably, you should also post a drawing so we can check whether there is some fault with the code output.
Personally, I know it is annoying when your controller hangs with an error, but if the end point is truely incorrect, then it is doing you a favour by refusing to cut the arc. There is no reason for a mathematical error in the nc code, if that is the cause of the problem.
If exactly the same code will run through one controller, and not the other, then the problem is in the hardware, or perhaps the (programmable Eprom) firmware of your controller. I trust that both controllers are set up with identical requirements for arc coordinate input?
Old 05-30-2003, 07:09 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Buried,
No luck with the number I PM you?
Let me know what they told you and I'll see if I can get you to somebody else at Anilam.
Tid bit: Anilam is Malina spelled backwards. Jay Malina was the guy who started Anilam, now a part of Heidenhain.
Old 05-30-2003, 07:30 PM
Moderator
Hmm, let me try that.
Gnudgnulfuh
OMG That's my real father's name!!
Old 03-14-2006, 06:18 PM
dragonclaw19 is on a distinguished road
Hey I just got a an anilam 3300Mk and I keep trying to contact them about the mouse plug. I see the seperate keyboard plug but no mouse. They are hard as heck to get a hold of. they never return my calls. etc...
I am very fustrated with the service. I bought this machine from perfomance Mchine and they arent much help either. So this is why I am asking the people here to hear my cry of help.
Thanks,
George
Old 03-14-2006, 07:38 PM
brianaldrich is on a distinguished road
try renew services in ct. 860-763-5366 they work on a lot of anilams ask for buzz he was head of service in ct. when anilam had a office there
Old 07-22-2008, 12:41 PM
alfaguzziboy is on a distinguished road
Worked for me
Don't know if anyone still has this problem, but I ran into it after finally brushing up on Surfcam after 10 years off. First, Anilam CAM support is non existent. They suck. Just tell you to generate G code and convert to Conversational and you are on your own. What finally worked for me was to go into Operator setup and Change Circle center to incremental from modal. It hasn't given me the message since.
Luck
Jim F
  #11   Ban this user!
Old 07-23-2008, 07:36 AM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Anilam Help
Hi Buried,
If you haven't contacted this guy I would do so as he can probably help you out. I had a couple of Seiki XL 3 Axis CNC mills with the Anilam 1100M controller on them. He was always extremely helpful when I called him.
Gerald W. Bouvier, Jr.
PH# 716-661-1883
Fax# 716-661-1884
E-mail jbouvier@anilam.com
Networking Specialist
Tim is the service manager and was also extremely helpful.
Tim Podgwaite
Service Manager
Acu-Rite Companies, Inc.
716-661-1724
Good luck in fixing your problem. PM me if I can be of further help. I have something that may be of use to you on your Anilam Control.
John
  #12   Ban this user!
Old 02-16-2011, 12:52 PM
Larry Patterson is on a distinguished road
Would you be interested in selling one of the Anilam 330 or parts.
Please call Larry at 801 216 4576 Thank you
[IMG] code is Off
RS-232 / Dnc, Pc To Anilam Crusader 2 Anybody Doing It? jpb6061 General Metal Working Machines 10 05-18-2007 07:12 AM
anilam glass scale incorporaton johnd General Electronics Discussion 1 05-05-2005 10:09 AM
Post Processor for Anilam 6000 dswartfager Post Processor Files 0 03-03-2005 09:57 AM
Anilam Crusader 2 Help plascom General Metal Working Machines 4 01-23-2005 05:10 PM
anilam mk3200 axe Post Processor Files 4 09-08-2003 09:04 PM
