Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-28-2003, 07:04 PM
gevannos is on a distinguished road
Question rotary cloth cutting tool
Hi All
New here and so far love the site.
I have a shopbot tool and normally cut plywood boat parts.
i want to cut cloth and would like to add a rotary trailing type cloth cutter. Has anyone seen a rotary fabric knife attachment for a cnc router machine??
Eric
Eric Van Nostrand
Old 04-29-2003, 12:04 AM
Max's Avatar
Max Max is offline
Max is on a distinguished road
I posted this response to you on another site before I found this one ...
Take a look at this guy's site
http://www.carlsondesign.com/
You may get some ideas or be able to retro one of his cutters to your machine.
He also has some boatbuilding links and software
Old 05-15-2003, 06:30 PM
coherent is on a distinguished road
Those cutter heads are nice. I guess the price isn't bad if you were in garment cutting as a business. Seems like you could cover your sacrificial table top with a cutting matt and mount a standard rotary cutter knife blade on a spring loaded shaft that swivels for well under that price... most likely with hardware store parts... shouldn't be much harder than retrofitting one of his cutters?
-Marc
[IMG] code is Off
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 08:51 PM
Rotary tool paths DAB_Design Mastercam 1 03-31-2005 02:27 PM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 09:56 AM
Best tool for cutting metal? PsyKotyk General Metalwork Discussion 4 04-01-2004 03:10 AM
Cutting tool shape for PCB milling NeoMiller General Metal Working Machines 2 11-13-2003 12:09 PM
