Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-20-2004, 08:40 AM
jbhill is on a distinguished road
CNC Lathe Cutting Small Threads
We are trying to cut a 3/8-16 thread 1-1/4" long in 1018 steel using an Iscar insert and a Mazak QT-10 lathe. We can only go to 95 SFM without a program error (not enough acceleration distance) but that is really leaving a terrible surface finish. We tried a number of things, even making up to 20 passes but it always yields the same results. Does anyone have any suggestions?
Thank you,
Jason
Old 05-20-2004, 12:26 PM
mrainey is on a distinguished road
Sometimes a cermet insert will cut cleaner on gummy steel.
Old 05-20-2004, 01:41 PM
wjbzone's Avatar
wjbzone is on a distinguished road
Have you checked your insert alignment? (is it on center, is the helix angle correct .) Do those inserts require an anvil?
Bill.
Old 05-20-2004, 03:15 PM
HuFlungDung's Avatar
Moderator
Using a positive rake insert will help a lot, I do not know what the Iscaar thread tool looks like.
What kind of approach are you taking? A simple 90 degree plunge is not a good method, because of the excessive chip width, especailly when your SFM is low.
Brushing on a good threadcutting oil might also help improve things a bit.
I suppose you are right out of room to increase the start distance in front of the thread, so that you could run faster and not get the error?
Old 05-20-2004, 03:28 PM
I wish we could afford cermet! The insert is on center and I'm not sure about the helix angle, these inserts fit in the grooving holders so no anvil is required. We are approaching at 29-1/2 degrees (59 in the program of course). We found out that there is a parameter in this control (T-1 plus, ancient) that will allow us to increase the accelaration distance. We did that and ran to 200 sfm. Still low but it is more than 2000 rpm, probably enough for this old machine. The threads look much better but there is still chatter for the first 1/2" of the part. I guess with no tailstock and this length of part we might be better off using something like a floating die holder... Thanks for all of the help.
Jason
Old 02-19-2005, 09:53 AM
oldjohn's Avatar
oldjohn is on a distinguished road
G'day
Have you considered rolling threads?
[IMG] code is Off
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 01:06 AM
Manual lathe CNC conversion kong General Metal Working Machines 10 08-20-2005 04:56 PM
Pictures of My Lathe & CNC MILL studysession General Metal Working Machines 14 01-04-2005 05:07 PM
My Lathe project; might CNC it one day Stevie General Metal Working Machines 86 06-21-2004 09:27 PM
Help to pick small (not mini) CNC Lathe 5axis General Metal Working Machines 5 02-03-2004 06:35 PM
