| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Has anyone here used moglice to reduce the backlash on their acme screws? I'm playing around with a mill/drill that has about 0.015" backlash on the X and Y axes, and would like to get that down to less than 0.003" backlash. Is moglice capable of doing this? Also, where is a good place to buy it? |
| What the H is moglice?
| I know what it is geezz I thought I was dumb to , (just kidding) I did a search and what it is, is Moglice FL/P Formulation Date 1988 - is a fluid with a consistency similar to gear oil. It can be injected or poured to produce way systems, quill bores, nuts or tapers. It is also used in the pour and set application technique. Moglice P-500 Formulation Date 1986 - is a slightly thicker fluid with a consistency similar to honey. It is still injectable and is often used in ball nut applications, air bearings and in the production of sub-micron accurate bores. Moglice 628 Formulation Date 1985- is a semi fluid having the consistency of a thin putty and tends to run on a vertical surface with minimal damming required, but will not run off a flat way. It is most commonly used on machines with large flat ways because it is easier to mix, apply and get the component down and aligned. Moglice Putty Hard Formulation Date 1983 - is a no-slump putty and is the most common material used on standard way systems. It can be applied to vertical or overhead surfaces without running or dripping. Moglice 1000 Fluid is a fluid about the same viscosity as the Moglice P-500 above. Moglice 1000 Fluid differs in that it contains Teflon and results in a 25% to 30% further reduction in friction. It also provides added protection against moisture absorption. Here is the website - http://www.moglice.com/
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com Last edited by CNCadmin; 04-22-2003 at 01:39 PM. |
| Sounds like wishful thinking to make it absorb backlash. Its probably viscous as dickens and makes the screws difficult to turn. If you are trying to reduce the backlash in a standard Acme thread, it would be better to face off one side of the existing nut (or the casting, etc), cut a new thread in a disk that you can fasten to the face of the old nut. Then, shim this disk away from the face of the existing nut until you have reduced the backlash. Use bearing bronze or aluminum bronze (best but toughest to cut) to make the nut. Another method involves splitting and then finding a way to collapse the threads of the existing nut, but this the least desirable method because it tends to pull the screw offcenter, especially when you get near the extremes of travel.
I've contacted Devitt Machinery, and they answered all of my questions well. I'll be purchasing some moglice and using it this weekend. It should cost less than $100, which seems very fair to me. I'll let you guys know how it goes, since it seems there's not many around here who have heard of it. |
| Yes it will be interesting to see how it turns out. I didn't understand that is what it does. But, this begs the question, how do you make it give you the tiny bit of clearance that you need to get the screw out of it after it hardens up? Spray paint the screw first perhaps to try to achieve the thickness of the paint skin for clearance?
#10
| Hu, I Thinks the stuff "shrinks" a little as it hardens up, hence your clearance. Ah the magic of chemicals.
#11
| Could still be tricky in the narrow confines of a nut, where the thickness of the injection is only going to be .007 to .015. I'd be surprised if the bond is super strong to the one surface, and yet provides clearance on the other. It is very difficult to even clean a nut to be chemically clean enough to provide a good bond without some kind of acid etch. Then to also provide a non contaminating release agent on the screw, and get it into position without contaminating the interior of the nut would be miraculous. I think that for the method to work, you'd almost have to saw the top half off the nut, then bolt it back down for the duration of the procedure, then open it up to release the screw again. But, anyway, we'll sit and wait for the play by play.
#12
| Here's the basic procedure as I understand it. (I've never done this before, so this may not be correct).
The release agent dissolves in oil, thus giving you the required clearance with minimal backlash. If clearance is too tight, use lapping compound to increase the clearance. Like I said, I've never done this, so there may be some errors in what I just said. Hopefully I'll know for sure after this weekend.
__________________ My name is Electric Nachos. Sorry to impose, but I am the ocean. http://www.bryanpryor.com (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Cheap sliding ways | chuckknigh | DIY-CNC Router Table Machines | 6 | 02-04-2009 09:21 AM |
| Moglice Substitute? | cbcnc | General Metal Working Machines | 4 | 08-01-2003 07:36 PM |
