Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 06-01-2007, 08:25 AM
ismaithliom56 is on a distinguished road
Question Sharnoa SD 30 wiring diagram
I have a Sharnoa SD 30 with a Sharnoa tiger 4 control Ser# SE23835 that is based on a Lagun mill. I need a wiring diagram for this machine to repair it. It seems fully functional except that I can not get the drivers to lock on. The last company that had it let an inexperienced person work on the control box and they have left one 24 volt power line free and I can not figure out exactly where it should go and I really do not want to cause more damage than I repair. If any one has a wiring diagram for this machine I would really like to get a copy. Thanks
Old 11-26-2007, 11:02 PM
SIG SIG is offline
SIG is on a distinguished road
Did you get this sorted out?
If not I can try to help. We have the same machine.
[IMG] code is Off
need Eurospark 740 wiring diagram kh_khayat CNC Plasma and Waterjet Machines 1 08-02-2009 08:47 AM
Control Box Wiring Diagram bigvinney General Electronics Discussion 0 01-22-2006 04:57 PM
Wiring Diagram Proof stein Gecko Drives 6 01-10-2006 11:29 PM
Wiring diagram geckos freak_brain Stepper Motors and Drives 0 01-09-2005 12:25 PM
