Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-20-2007, 02:45 PM
NC Cams is on a distinguished road
CDROM burning via DOS
At one time I had a link for this topic but it got lost.
TOPIC: I am looking for a way to BURN (not read!!!) CDROM's via DOS.
Reason: I have some legacy computers and need to B/U the data on them. The files are too big and/or too many to dump them to floppy's. Besides, the data that we have backed up on some floppy's has gone bad and they were sitting in a well protected remote area. Thus, we want to put the stuff on CD's for B/U.
Does anybody have a link or a method to take a lowly DOS PC and add a program to it that will enable the burning of CDROM's????
Old 05-20-2007, 02:54 PM
paulC is on a distinguished road
You would have to find an old DOS version of CD burning software.
Would it be possible to remove the drive from the old PC and attach it as a second drive to a newer machine. Or perhaps get the old PC on to a network and copy across the network. Remember the old fastlink cables. Another option.
Paul
Old 05-20-2007, 03:36 PM
I have some old software that would burn CDROM's. Trouble is, it wouldn't recognize that the burner existed in DOS and or Win 95 = even after we loaded a bunch of ASPI files and the what not.
I had a link at one time to an aftermarket sitewhere a programmer from Europe that supposedly had written some betaware that would allow you to load a program that would emulate enough of Win 98 so as to fool DOS into thinking that it was 98 enough to run a burner.
However that is the link I lost and can't find anymore.
I couldn't find it via Google nor via this fine site's search engine even though I thought it was mentiond, discussed on the site at one time..
Machine packaging issues preclude the possibility of patching in aother HDD for data transfer - if I could do that I would.
Undoubtedly, in this case, the easiest way is to load a program on existing HDD and swap the existing CDROM out for a ROM burner.
Old 05-20-2007, 03:57 PM
epineh is on a distinguished road
There were some good parallel port file transfer programs we used to use in the "good ol DOS days", I cannot remember the program names but I will google for them after work today...they were simple and surprisingly fast.
Russell.
Old 05-20-2007, 04:23 PM
I somehow solved my own problem due to being too tired and lazy to do anything short of websearching:
The CDROM burner for DOS is located here:
http://www.freeweb.hu/doscdroast/index.htm
There are a bunch of neat DOS programs, including some parallel and serial port file transfer programs here:
http://www.opus.co.tt/dave/utils.htm
Old 05-21-2007, 04:16 AM
I was on that site earlier today (just after I posted) and for some reason my popup blocker was turned off, man it was popup central, but as you mentioned there were some neat programs... and much easier to view with popup blocker on...
Russell.
[IMG] code is Off
Laser Pionter Encoder || Cdrom erlyrisa General Electronics Discussion 0 05-17-2007 12:35 AM
The wood is burning studysession DIY-CNC Router Table Machines 2 05-06-2007 07:37 PM
drives burning up thespindoc General Metal Working Machines 5 04-03-2005 06:00 PM
Need help installing windows 95 - cdrom wont read Hack Computers and Networking 6 02-14-2005 10:03 PM
Servo motor is burning Alex S.A Servo Motors and Drives 23 09-07-2004 12:15 PM
