Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-05-2004, 05:47 PM
envision is on a distinguished road
Arrow mastercam / dynapath problems
I have been searching the web for a updated post for mastercamV9.0. I have used mastercams defaults delta40
and dynapath20 settings. The 20 works great on the machine and does everything properly except rigid tapping and the coolant turns on before the tool change. (the toolchange call turns the coolant off). The delta40 dosn't work at all.
I have talked to the people at autocon and they told me there control needs to have each G code on a diffrent line. It crashes the control if the is two or more on a line when I do a RS232C trickle feed. (this is what is wrong with the delta40 setting)
If someone can give me some info on either editting the setting files in mastercam or a post that is works with mastercamv9 and a dynapath 50M controler, or option C, tell me to get my head out of my #@!. The default will work, I am just doing it all wrong.
Any input will be appricated.
Thanks for your time.
Mike.
[IMG] code is Off
How do i get my autocad file onto mastercam? EdE General CAM Discussion 3 02-23-2011 12:54 AM
Mastercam 8 post help for Dynapath 10 greggv Post Processors for MC 7 01-07-2010 03:37 PM
Mastercam with *old* Hurco CNC Miller ReValveiT Mastercam 25 05-19-2006 08:01 AM
Bold Tool Path Lettering in MasterCam Operations Manager ngr1 Mastercam 2 06-08-2005 07:58 AM
Mastercam Jingle Bells Rekd Mastercam 3 01-02-2005 02:20 PM
