Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-16-2007, 04:05 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
rs232 question
all our machines are wired to the network at which we hire a guy in to do all the wiring , something ive never bothered to pay attention to
what i want to do is load a program from a laptop ,
the communication on the machine is rs232
will a standard cable such as this work http://www.staples.ca/ENG/Catalog/ca...affixedcode=WW
i m going to be using cimco editor to upload from
also in the machine parameters it shows rs232c1 rs232c2 ,what would that be about ??
thanks
curt
Old 05-16-2007, 06:15 AM
audioandy1762's Avatar
audioandy1762 is on a distinguished road
Hi Curt
As the name implies "232" the wires are crossed pin2 on one end of your cable to pin 3 on the other and vise versa also connect pin 5 on both ends.
Hope this helps
Andy
Old 05-16-2007, 08:04 AM
jackson's Avatar
jackson is on a distinguished road
yes you have to custom build your cable
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 05-16-2007, 08:17 AM
dertsap's Avatar
Gold Member
so will the rs232 cable in the link i posted not work ?
Old 05-16-2007, 09:12 AM
jackson's Avatar
well in the link it wouldnt let me see anything i always get the stuff at radio shack
Old 05-16-2007, 01:34 PM
Hi Curt
The link only takes you to a post code search.
Andy
Old 05-18-2007, 12:42 PM
mroy0404 is on a distinguished road
I used a RS232 cord from a store and it blow a fuse on the I/O card. I had to custom make a RS232 cord for my Fanuc 10M.
Old 05-18-2007, 02:07 PM
rancherbill is on a distinguished road
Maybe Yes, Maybe No
Get an existing workng cable. Using a meter check for continuity on pin 2 between ends.
If there is continuity then it will work.
IF there is continuity from pin 2 to pin 3 then get a NULL MODEM cable.
Old 05-19-2007, 08:46 AM
CNC Pro is on a distinguished road
Here are a couple sources that might be of interest.
http://nullmodem.com
http://www.cablewholesale.com
Old 05-19-2007, 09:13 AM
thanks
curt
Probably it will not work. I went through several places before I found one that had the correct cable.
Here is a picture showing the pin connections you can check.
Old 05-19-2007, 09:20 AM
Al_The_Man's Avatar
Take a look here, http://www.cadem.com/dnc/ncnet_dncdetails-41.htm most machines are listed as to cable and parameters, I have found the majority will work with the three wire cable, i.e. Hardware handshake jumpered.
Old 05-19-2007, 02:08 PM
dertsap's Avatar
Gold Member
thanks guys ,
i think i'll wait to talk to our communications guy , i would hate to have something to go wrong and fry a machine port or something ,it looks pretty straight forward to make my own cable and all but i know i'm going to get stomped on if i blow it , it s nothing pressing at this point of time to have it , it s more for me to design on the fly any fixtures and such or to resolve programming issues or the odd government job , i do a fair bit of hand programming at the machine so this will make my life a lil easier, in my day any minutes saved are like gold and one less tylonol
[IMG] code is Off
Fanuc 11M RS232 9566317 Fanuc 16 02-22-2010 12:34 AM
Meldas 64 ASM and rs232 KombianCNC Mazak, Mitsubishi, Mazatrol 7 12-20-2007 04:31 PM
RS232 Help Jerrytool Daewoo/Doosan 9 03-15-2007 05:51 PM
USB to RS232? Klox Computers and Networking 7 11-29-2006 02:11 PM
Mach2/3 and RS232 jderou Mach Software (ArtSoft software) 2 05-28-2005 07:10 AM
