Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-04-2007, 03:10 PM
tjurek is on a distinguished road
Mitsubishi DWC-110H A Wire EDM Floppy Problem
Has anyone ever worked with one of these machines? And if so... how do you create a floppy disk to read in it AND on a PC. The only reference to the file system on a floppy readable by this EDM is a CP/W format. I downloaded several floppy readers that supposedly read CP/M formats but none of them recognize the disk.
At present using a serial cable isn't an option so I would really like to get this floppy situation sorted out as standing at the machine typing in several thousand lines of code is not my idea of a good time...
Thanks in advance to anyone willing/able to help.
Old 05-31-2007, 01:18 AM
Beemon is on a distinguished road
Question the same problem
Have you succeeded in solving this problem? I can still go with the option of serial cable, but it would be good to have a reserve solution.
Thank you, Beemon
Old 10-04-2007, 02:45 PM
nastek is on a distinguished road
Dear Tjurek,
For transfer G Code From PC to DWC 100HA (32 Bits System ), you can send by Floppy Disk 2HD that formatted By 720K MsDos.
you can format on Windows, Usually on 95,98 system
greeting
Tarom
Focus Electric CV.
Official Service and Training
Mitsubishi Electric
Indonesia
Old 10-10-2007, 08:12 AM
JSaindon is on a distinguished road
I dislike the lack of standards in industry. We have machines that only use HD disks (manual did not even say that) and machines that can only use 700K DD disks (our Mits. EDMs). nastek, can you explain why Mitsubishi does this and what is the reason for it? It seems like a silly limitation for an expensive piece of technology. The only thing I can think of is the DD is more stable in the fact that it has better data corruption prevention. Since the tighter you pack the data together on a floppy disk, the more the chances of interference between adjacent tracks. Therefore, higher density disks use weaker write signals, and different magnetic coatings than lower density disks. So DD would be the way to go since the data isnt packed in as tight as with the HD disks. Answered my own question I think.
Old 10-10-2007, 02:33 PM
Dear JSaindon,
Since Mitsubishi released 16 bits system (80's), they use CP/M program.
ON 90's (32 Bits)they adapted 720K DOS system on the CP/M program. but it only can read for parameters disk and NC program.
I think they use for protecting the program ( other controller do like that )
On 1998 the introduce 64 bits system, based on Windows 95.
i don't know what exactly the reason, but i think CP/M on Mitsubishi is stable system.
Mitsubishi can read DD and 2HD that formatted with 720K Dos.
I can not answer your question with specific data.
I only know that 32 bit system can read 720K dos and
64 bits system can read whole Dos format, But can't read CP/M format.
for more information please visit www.diax-net.com
regards
Nastek
Old 10-11-2007, 07:08 AM
Thanks for the reply. Nice to know the info.
[IMG] code is Off
mitsubishi wire cut DWC90 C2 camay CNC Plasma and Waterjet Machines 4 04-17-2012 09:58 PM
Biesse Rover 335 floppy problem guncha1 Commercial CNC Wood Routers 33 01-05-2012 03:54 AM
Floppy start for Japax Wire EDM hien100881 CNC Wire Foam Cutter Machines 1 10-10-2008 09:42 PM
Mitsubishi, DWC-110G Wire EDM professor CNC Plasma and Waterjet Machines 1 03-02-2008 02:56 PM
Mitsubishi H110 Wedm Wire Problem osomaker CNC Plasma and Waterjet Machines 1 12-11-2006 12:23 PM
