Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-31-2007, 11:21 AM
Tenextoolco is on a distinguished road
Bar Pulling On A Femco CNC Lathe W/OT Control
Hey Guys,
I`m having problems getting the control to pull barstock with this control.
The puller comes up to the part and stops when I put the M11 code in. Do I have to program in incremental to get the machine to move?
Old 03-31-2007, 11:29 AM
I forget the code but try giving a feed per minute command before the M11. With the spindle stationary the normal feed per rev doesn't go anywhere...no revs .
Old 03-31-2007, 01:10 PM
WayneHill's Avatar
WayneHill is on a distinguished road
Use absolute dims. Less confusing.
(OPEN CHUCK)
G01G98Z.29F100.
( CLOSE CHUCK )
G99...
Wayne Hill
www.codemangler.com
Old 04-04-2012, 12:30 AM
gusjunior2000 is on a distinguished road
hello everyone, I am new in this forum and I have almost the same problem and some how I was able to fix it, now the problem that I have is that when I command M11 the chuck opens but not enough to release the material stock. What I did was that I put a sequence of m11 and M10 to open and close the chuck but I do not feel comfortable, what I do not know is if there is a timer that controls the timing for opening or closing the chuck and can be modified on the parameters, any help will be appreciated.
Old 04-04-2012, 12:57 AM
txcncman is on a distinguished road
G04 dwell
http://www.kirkcon.com/
Old 04-04-2012, 01:00 AM
dcoupar's Avatar
You don't say what make and model machine you have, so it's hard to know what the situation is. Some machines have proximity switches on the cylinder to confirm chuck clamp/unclamp, some use PMC timers.
You could add a dwell after the chuck open:
M11 (OPEN CHUCK)
G04 X2. (DWELL 2 SECONDS)
G01 G98 Z0.5 F50.
M10 (CLOSE CHUCK)
Old 04-04-2012, 11:23 PM
hello again the machine that I have is a femco durga 25e 1994 and I did not see any switch to control clamp and unclamp, also I already put g4(dwell) to give some time but it still does not work, the only difference that I noticed was that I put G4 P3000 instead of G4 X2. I will try to do it using G4 X2. thanks for your help.
[IMG] code is Off
Femco Lathe leggetmachine General Metalwork Discussion 1 03-31-2007 11:29 AM
Pulling force meter Green Button General Metal Working Machines 1 09-26-2006 01:36 PM
Femco Z Axis Way Cover swartling General Metalwork Discussion 0 07-07-2006 10:59 PM
Mazak QT-10 Bar Pulling jbhill Machine Problems, Solutions , Wireless DNC, serial port 2 08-09-2004 07:16 AM
Is Taig pulling my leg? c131fr Taig Mills & Lathes 27 07-12-2004 04:31 AM
