Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-19-2007, 05:10 PM
mmurning is on a distinguished road
Drip feed or Dnc A Prototrak Mx3
Has anybody here been able to drip feed a prototrak mx3, and if so could you help a brother out and show me the way......thanks
Old 03-23-2007, 01:25 AM
Eighteenten is on a distinguished road
Hi mmurning,
This series of controls does not any method of handshaking for RS232. This makes reliable communication very hit and miss. I would recommend you use a BTR (Behind Tape Reader) for these controls to upload and download into memory.
Old 05-29-2007, 11:12 PM
Swag's Avatar
Swag is on a distinguished road
Thumbs up
I have a Prototrak AGE3 about same as MX3 reads mx3 files too , I dnc to it
data bits - 7
parity - even
stop bits -1
handshake - Xon/Xoff
baudrate for DNC can be set by running service code 37 , I run mine at 9600
buadrate for cam files is always 4800, programs you just send to memory of the machine , I hope this helps
Mark
forgot you have to have the DNC key to do so, its a $1500.00 option from SWI
You can tell if you have the DNC key by going to program in/out if you see DNC as an option its there.
[IMG] code is Off
Inexpensive DNC for Drip Feed Tazzer Machine Problems, Solutions , Wireless DNC, serial port 3 01-28-2008 05:27 AM
Drip Feed Fanuc 18i MoldMaker Fadal 0 12-26-2006 10:56 AM
Drip feed Boss9 pcsimp Bridgeport and Hardinge Mills 5 08-12-2006 07:38 AM
Drip Feed camtd Surfcam 0 07-31-2006 06:09 PM
Just found out I won't be able to drip feed w/RS232 jderou Bridgeport and Hardinge Mills 7 05-29-2005 03:36 PM
