Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-18-2007, 01:32 PM
dewcnc is on a distinguished road
Yasnac i80, Rs232 problem
Hi, I have been trying to communicate to my machine through the rs-232 port with no luck. The machine has a Yasnac i80M controller. I am able to sent programs from the machine to the computer(upload) but the program looks like jibberish. When I try to download a program to the machine my dnc software states it is waiting on responce from machine tool.
I have all of the port settings configured the same on both ends.(Data bit, Braud, xon/xoff, etc.)
I think maybe the machine parameter settings are not correct, but have no idea which setting effect the upload and download of programs.
I have connected several machines in the past, but I must say this one has me stumped.
Thanks in advance for any ideas on what to try next.
Old 03-18-2007, 01:41 PM
Al_The_Man's Avatar
Jibberish usually indicates baud rate wrong, If you cannot see or confirm what the machine is set to, try uploading to PC, with PC starting at 1200 baud both 7 bit & 8 bit data, and work your way up to 9600 baud.
Old 03-19-2007, 09:09 PM
jghuttora is on a distinguished road
hi i'm having problem sending program from my laptop to yasnac300 on matsura 800-vg 11 . I'm using bobcad to send signal to my machine using RS-232 USB whats happening is either it shows inputting completed with alarm 9014 says DR Unready, After playing with settings sometimes it start showing inputting which flashes on my machine screen on my laptop it shows its sending even on the usb serial port cable this light blinks as it is sending the signal but in reality nothing is happening please suggest what is that i'm doing wrong.
Old 03-19-2007, 09:20 PM
Old 03-23-2007, 02:37 PM
Ok, I can upload a program from the machine and everthing looks good. However I can not download a program to the machine. Could this be a bad board in the machine. I have traced all the cables back and everthing is ok with the wires. Has anyone ever had this problem?
Old 09-16-2008, 05:00 PM
mastercamguru's Avatar
mastercamguru is on a distinguished road
I had a similar headache with a MCV510-VF w/I80 control.
Assuming you are using a 3 wire connection without handshaking. :
The I80 control at 9600 baud can only be used with: 8 data bits/ 2 stop bits/ even parity/ xon/xoff disabled. (xon/xoff will only work if you have a partial or full handshaking cable) ie: the machine will wait forever for a DSR / RTS signal
Old 12-04-2008, 04:26 PM
duklatd is on a distinguished road
YASKAWA can help you Call 1-800-927-5292 . They are expert on this control and can service your machine too
Old 02-13-2011, 02:24 PM
LUIS SANCHEZ is on a distinguished road
did you check cables (pins )connections?
Old 02-18-2011, 12:03 AM
shahid@cadem's Avatar
shahid@cadem is on a distinguished road
Arrow RE:
This indicates that there is no parameter related issues now, its only a cable issue I think!!
Try the std.null modem cable (ref the attachment).
[IMG] code is Off
Okuma OSP100E RS232 Communication Problem Edster Machine Problems, Solutions , Wireless DNC, serial port 6 03-20-2007 06:57 PM
Cnc Milling Problem (mitsui Seiki- Yasnac Mx1) le_hungvn General CNC (Mill and Lathe) Control Software (NC) 0 11-16-2006 01:44 AM
Rs232 Problem j-radkemachine Haas Mills 1 10-06-2006 10:03 AM
RS232 seup problem with Meldas50 Caboose Machine Problems, Solutions , Wireless DNC, serial port 19 03-16-2006 06:51 PM
RS232 problem sending with newer PC sys_man Computers and Networking 15 06-10-2005 08:36 PM
