Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-10-2007, 02:50 AM
burroughs is on a distinguished road
How to fix Zero Return after crash
Hi, I've got a problem with my Y axis on my Excel 810 after I crashed on the Y axis. I cannot do a zero return without getting an overtravel alarm. When it stops on the limit switch it the machine position shows it to be +.040.
It was kind of a hard crash that "tripped" the Y axis (unfortunately, nothing on the table gave way). While searching I found some information about servo couplings slipping in crash.
Any thoughts about how to diagnose and repair? Any help would be greatly appreciated. Thanks.
Old 03-10-2007, 02:58 AM
Jarwalcot's Avatar
Jarwalcot is on a distinguished road
Try moving all the axes to the center of the strokes, power down the machine (source power as well) turn source power on and while holding the "P" & "Can" buttons turn on the control... Hold the buttons until the machine completely powers up... Now try to zero the machine..
JR Walcott
Georgia Machine Tool Resources, LLC
Old 03-10-2007, 03:49 AM
It works
Fantastic! That worked fine. Thanks for the help and the fast reply!
Is that method the kind of catch-all (or at least the starting point) for addressing machine reference issues? I seem to have used that in the past , or something similar, but it's been a long time and not something I retained.
Anyway, thanks again!
[IMG] code is Off
Crash parameter x over travel adamant Fanuc 15 08-21-2008 06:04 AM
Restarting a job half way through after PC crash cpcp Mach Mill 9 04-16-2007 01:03 PM
Crash during Z rapid move AndyB Fadal 1 03-07-2007 08:48 AM
crash during smoothing henryj1951 Virtual Sculptor VS3D / VScad3 Software 5 02-11-2007 02:56 AM
Mastercam lathe crash course CNCnUtZ Mastercam 6 09-26-2003 01:03 AM
