Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-26-2007, 07:49 PM
9566317 is on a distinguished road
Cool Multi port Upload down load DNC
I now have 30 CNC Mills and laths. I have a upload down load system with multi ports.
I want to call up my required program from the machine and to send old program back to computer from the CNC controller. I can do this with up to 4 machines but when I open up the computer program and each machine directory I can only have 4 machines available .If I open more I get a Alarm on my computer saying it cannot open more. I think I need differant soft ware, One guy said a computer with more memory. Whats out there that will not break the bank for software. I had One software supplier in and they wanted 20,000 for it. Any Ideas here?
Old 02-26-2007, 08:52 PM
Al_The_Man's Avatar
Dan Fritz here has a product, I am not sure how many maximum, there is a server version also I believe http://www.rym.com/
Old 03-10-2007, 12:49 PM
gar gar is offline
gar is on a distinguished road
070310-1341 EST USA
9566317:
What is your definition of DNC?
If you need to do Direct Numerical Control (Drip Feed), then how many machines simultaneously?
If your CNC program memories are large enough to hold your complete program in CNC memory, then what are your memory size ranges, and what are your progam size ranges?
How many programs per day do you send to each machine?
How many files do you send to the computer vs files to the machines?
[IMG] code is Off
How to multi part Toddjones Mastercam 6 04-23-2009 10:02 AM
multi depths in 1 programm ajitsingh Bridgeport and Hardinge Mills 2 02-23-2007 10:11 AM
Multi-motors Tsukuyomi Stepper Motors and Drives 5 05-02-2006 08:45 PM
multi-boot two HDs Karl_T Computers and Networking 3 06-20-2005 11:58 PM
Multi Bit Drill Head smythe WoodWorking 0 11-16-2004 12:02 PM
