| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
| try a switch box can get one at any computer store it has six 25 pin ports on the back called a "data transfer switch"
__________________ individual who perceives a solution and is willing to take command. Very often, that individual is crazy. |
| Do you want to use one set of drives, or have seperate drives for each machine?
| For testing, what I did was use (Mojopac dot com) and set mach3 up in it. and depending on what machine i wanted to run i use the original operating system or used a USB stick running mojopac for the testing machine. Joe |
may be to consider using a USB to RS-232 hub. External USB to multi-port RS-232 devices (typically 4 ports) are available for a relatively inexpensive price.
__________________ Paul Sevin - Ovation Engineering, Inc. http://www.ovationengineering.com |
| Connecting rod | ACME | I.C. Engines | 18 | 08-11-2007 12:09 PM |
| Connecting the dots | monte55 | Vectric | 1 | 02-12-2007 06:11 AM |
| connecting steppers | BAM | Gecko Drives | 2 | 01-22-2007 05:06 PM |
| connecting | KrashKing405 | Open Source Controller Boards | 18 | 07-26-2006 05:30 PM |
| Need help connecting laptop to CNC | flyguy1254 | General Metal Working Machines | 1 | 10-20-2004 06:28 PM |
