Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-16-2007, 01:29 PM
BAD DOG is on a distinguished road
yang growl
1997 yang sl-12 cnc lathe
Z axis motor growls loudly as ballscrew is rotated. Growl is not rythmical.
will growl by turning handle or feeding or rapid in program.
If i rotate the handle I can get the motor to growl continuously at a certain rotation of the handle.
ballscrew and assembly turn smoothly, not a mechanical problem
bad dog
Old 02-16-2007, 02:11 PM
holbieone's Avatar
holbieone is on a distinguished road
sounds like you need to balance your drive board
[IMG] code is Off
