Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-10-2007, 04:15 PM
halmande is on a distinguished road
Cool Losing Stepper Steps Help Needed
I am using nanotec stepper motors 1200 oz/in. However I am continuously losing steps on Y axis (X axis Has two Steppers). My setup is like this:
Stepper Motor: ST8718L4008 1200 oz/in–serially Connected (200Steps/ Revolution)
Driver: Gecko Drive Microstepper set at 10 steps reduction
DC Motor Voltage: 48VDC (Mean Well 6 Amp Power Supply for Y axis only to avoid problems)
Current: set at 4 AMP (62K Ohm Resistor) (On the motor it says 4 amp, However, on the website specifications it says 2.83 Amp)
Steps per Inch: 449.1715 (Direct - NO gearbox installed)
Mechanical Drive: is square and OK using Rack and pinion.
Type of Design cutting: continous carving with small Circumference movements
Note: When cutting straight lines, Squares, and Circles the Machine is OK
Could you please advice me of what could be the problem, and how could I solve it.
Best Regards,
Hani Al Mandeel
Old 02-11-2007, 05:56 PM
pminmo's Avatar
pminmo is on a distinguished road
If I'm reading the document for that motor correctly its a 8 wire motor, 4A per phase. How do you have it wired, bipolar series, bipolar parallel, bipolar half coil? Your best option is bipolar parallel, and your current would be set to 140 percent of your nameplate rating or 5.6A. Also what software are you using?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
[IMG] code is Off
Y Axis keeps losing Steps Normsthename DIY-CNC Router Table Machines 7 11-05-2006 05:26 PM
Losing X steps, stepper to small?? matth DIY-CNC Router Table Machines 20 09-06-2006 12:48 AM
Losing steps - WHAT IS UP?!? Sporqster DIY-CNC Router Table Machines 10 04-27-2006 09:50 AM
HobbyCNC board Z-axis losing steps raiven Stepper Motors and Drives 8 07-06-2005 02:53 PM
Cause For Losing Steps? FLUTE HEAD TurboCNC 7 06-14-2005 07:54 AM
