Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-25-2007, 10:33 AM
RogerN is on a distinguished road
Anilam Crusader ML Problems
I picked up my eBay lathe with the Anilam Crusader ML control, got it set in
place, wired the control, turned it on and all I get is a vertical glowing
bar, about 3/4" wide on the display. When I push buttons on the control,
there is no beeps or anything. This was supposed to be running when the
shop shut down, but they claim that it won't run if too hot or too cold. I
found the too hot problem, the muffin fan under the control hums but doesn't
turn. This thing has to be used in my car port for now, I have walls on 3
sides but no front door, anyway it's not much if any warmer than outside
temp. I have been busy with other work and haven't even gotten to check
fuses and power supply voltages yet. If too cold is the problem I'll put a
heater in the control cabinet.
If I can't get the it running right away, I'm considering temporarily
removing the servos and using steppers (I already have steppers, drives,
parallel port breakout, etc.) until I can get the Crusader running or
replaced with EMC2 and servo control card.
I have some questions for anyone who may be familiar with the control. Is
there supposed to be a beep when you push the buttons (like my crusader II)?
Have you ever heard of the control not working because it was too cold?
Thanks!
Roger N
Old 02-16-2007, 07:48 PM
bdambacher@dsl. is on a distinguished road
yes there is a beep when you press the keys. Try unplugging and re-plugging each board being careful to re-seat them in the mother board. the card cage might be deformed too, make sure it is not drroping, you might need to support it.
if all fails get each board out and clean it with contact cleaner and brush. make sure the boards are dry before you turn the power on again.
the motors wont be the problem here.
the ML control is not serviceable anymore.
Old 04-16-2007, 03:42 PM
kiwiavi is on a distinguished road
Keyboard problem
I had the same problem. In transport, one of the keys got a dent on the plastic covering and hence was continually being pressed. Fixed the dent and all working. Cheers Wallace
Old 05-10-2007, 10:23 PM
cacrawfo is on a distinguished road
Hello,
I had a Condor 1600 with ML control, and it would look funny untill the monitor warmed up. Also, the monitor needed to be adjusted. (small plastic screwdrivers, tiny pots on the video board, etc.) If you look closely at the CRT module, it is made by a major CRT place. Go to their website, and they have a PDF on where to adjust V hold, H hold, scan, etc. Also, my Anilam would never make the beeping noise. You can still find boards for these controls, I have a few contacts as well. Did you buy one of the Condor 1600 lathes from AMC SALES in Dayton? If so, I fell for you as I got the only good one they had
Carl Crawford
www.speed-source.net
C
Old 06-01-2007, 09:03 PM
Kevin Taylor is on a distinguished road
Hardinge with crusaderII control
I just bought one off of Ebay today control is suposibly able to power up and was running when put in storage but seller has no manuals for the control does anyone have a set that could be copyed from what I talked to analim I dont think they will be any help , do not pass go spend $7000.00 for new control . Has any one done a retro using the origonal servos and drives ? any help would be greatly accepted Thank's Kevin
Old 06-03-2007, 04:54 AM
Send me your phone number. I rebuilt an Anilam, works well and have a second which I will do a retrofit.
Cheers Wallace kiwiaviatxtradotcodotnz
[IMG] code is Off
Anilam Crusader 2 DNC/RS-232 CRAZYRICH Post Processor Files 6 10-10-2011 11:54 PM
V20 With Anilam Crusader II harvard5 BobCad-Cam 5 09-23-2011 07:55 PM
Anilam Crusader II - Crusader 2 Training DVDs Mike Mattera Product Announcements & Manufacturer News 2 07-08-2007 09:31 PM
Anilam Crusader 2 Help porsche1220 General CNC (Mill and Lathe) Control Software (NC) 3 04-09-2006 12:37 PM
Anilam Crusader M Tooler BobCad-Cam 1 07-07-2003 10:57 PM
