Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-20-2007, 04:21 AM
dungvp is on a distinguished road
Hitachi seiki seikos III
Hi All
I have a Hitachi Seiki VK45 with Seikos III Control , I getting alarm “ can not edit ( MDI running) “ in MDI mode. Can You help Me reset it
Thank You
Old 01-20-2007, 05:22 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
you d get more consistent help posting the same question only once
what is it you are trying to do in mdi mode
looks to me your trying to edit in mdi mode ,you can t do that
Old 01-22-2007, 09:39 AM
Hi Dertsap
Present I can edit new program in memory mode and then machine running no problem and DNC is same. But in MDI mode after I type any G-Code or M-function and then press Insert button, I just getting alarm "can not edit ( MDI running) “. can you help me ?
Thank You
Old 05-16-2007, 06:10 AM
miguisu is on a distinguished road
Exclamation help
hi, my name is Milton Suarez, and i work in a manufacturing plant. I have two HITACHI HT-50G, with SEIKI-SEICOS A10L control. We were uploading a part programm, and there was an electric overload between the p.c and the cnc...obviusly, the port for comunicate both, was damaged, and since that moment up to now, we couldn´t transmit anymore... neither uploading nor downloading. We had the same problem in another machine with Fanuc control, we solved it changing the port conection in the control from the RS-231 com 1 to rs-232 com2... in this way, we continue transmitting without problems. My question is, do Hitachi machines have other COM port as alternative? I opened the back gabinet, and i saw that there is a label where you read "RS-232 C2", but it belongs to a printer, and the conection is not the same as the common RS-232 serial 25 pin conection.
As you see, i´m lost. i need to transmit again, i don´t know if i could use this other port, and if not, i´m afraid that i not be abble to fix the broken port.
Any help that you could give me, is the most welcome.
Thank you !!!!
[IMG] code is Off
Hitachi Seiki Seicos Enda Fanuc 6 12-15-2009 11:14 AM
Hitachi Seiki with Yasnac LX1 besc General Metalwork Discussion 14 12-20-2007 08:35 PM
Hitachi seiki seikos III dungvp General CNC (Mill and Lathe) Control Software (NC) 1 01-20-2007 04:10 AM
Hitachi Seiki cre8tunes CNCzone Club House 0 11-17-2006 07:40 PM
Hitachi-Seiki HG 400III STCman General CNC (Mill and Lathe) Control Software (NC) 0 11-06-2006 10:41 AM
