Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 12-12-2006, 05:34 AM
Alex S.A is on a distinguished road
Better Way To Stop Machine
hi Guys,
I am wondering what is the best way to stop the machine and it keeps the correct position when it is under alarm condition. Is it using the E-stop or take out the ON signal sent to driver?
The machine is a gantry, with CNC and servodriver AC.
Old 12-12-2006, 07:56 AM
Al_The_Man's Avatar
If the controller and feedback system is kept active, the vast majority of true closed loop systems will know the machine position when the drives are not enabled or with power off.
Usually a precautionary measure is carried out in the control that senses when the drives are inactive or in an e-stop position that will zero the command signal so that if the motors are physically turned with drive disabled, it does not force the motors to jump back to the original position when the power is restored, but the correct position is always known, if servo with encoder feedback.
So that if the power is restored, this will now be the updated machine position.
It will always be referenced from the original home position.
[IMG] code is Off
