| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
| I'm a new member here and I'm very impressed with this forum! Her's my prob. My Meldas3M gets the semicolon flu when I DNC a file out of cimco. Everything works well until the word "END" ,which is in a comment, is read by the control. Then the cnc stops with a P32 "address error" I thought comments were ignored. So to fix the prob I edit "ENDmill to E-mill" What Gives! Last edited by GEARBUD; 02-03-2004 at 01:12 PM. |
| Glad to have you aboard!
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| Interesting..... What are you using as your comment character. My gcode uses a "(" and then a ")" closed one on the end.
__________________ Thanks Jeff Davis (HomeCNC) http://www.homecnc.info (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Thanks Jeff, I do use rounded brackets at beginning and end. One time when having this prob I went back and spelled the suspected word backwards and the controler liked it. On programs used from controler memory these comments never have bothered. Sure is strange! |
| Just a thought, maybe Cimco is interpreting the (END) as something "special" and doing something with it, like converting it to something else as it send the program tot he machine, kind of like a "search and replace" |
| My Mitsubishi manual shows error P32 as ADDRESS ERROR 'An address not listed in the specifications has been used'. The given remedy is 'Check and revise program address'. I have never come accross this before and the explanation is a bit cryptic. ![]() It looks like the control sees it as an illegal address for some strange reason. Al I just noticed this was first posted in March last year so I guess you may have it figured by now.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Fanuc 3M DNC operation | max_c | General Metal Working Machines | 3 | 07-04-2010 08:11 PM |
| DNC with parallel port (Bridgeport BOSS 5)? | hobbymat | General CAM Discussion | 3 | 07-20-2009 12:16 PM |
| dx32 dnc | Alan bailey | Bridgeport and Hardinge Mills | 9 | 11-06-2006 08:14 PM |
| DNC an old BPT BOSS | machintek | Bridgeport and Hardinge Mills | 8 | 05-20-2005 06:30 PM |
| Dnc Faldal | motomitch1 | Mazak, Mitsubishi, Mazatrol | 5 | 01-13-2004 01:56 AM |
