Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 12-07-2006, 03:44 AM
wstephens is on a distinguished road
acromatic 950
having trouble learning cincinnati mill
best i can tell something has caused my h3 offset to be locked in tracking mode @ b rotation.
when i call h3 b (x moves+/- or limit alarm).
all other (h) ofsets apear ok
please help
Old 12-23-2006, 04:50 PM
meckardt55 is on a distinguished road
When you put in an offset it is only turned on when the B- axis is at the position that is in that offset. Most common is 0,90,180 and 270 degrees. Move to the right in the offset screen and you will see the B-axis position and it must match where you want the offset to occur.
[IMG] code is Off
