Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 11-27-2006, 08:03 PM
wjfiles is on a distinguished road
Exclamation Limit switches question
Sorry if this is not the right thread.
Having read many threads, all recommend 6 limit switches for a gantry router/mill. One on each end.
Does anyone see any problem with single switch on each axis activated by a ramp at each end. The switches connected in series.
The switch having a roller and the ramps adjustable to set the limit positions.
I will be using Mach3 and a HobbyCNC controller
The More I Learn The Less I Seem To Know
Old 11-27-2006, 08:24 PM
drawbar's Avatar
drawbar is on a distinguished road
One overtravel limit switch per axis with two ramps per switch will work just fine as you have described. If you wire them in series, I would recommend that you use the normally closed contacts so that all switches make a complete chain in series, and opening a single contact would break the chain and trip the overtravel input. (Perhaps you had this in mind already, I was just checking)
Brian
Old 11-28-2006, 02:36 AM
Smile Thanks
Thanks for the reply,
I could not see any gremlins but experience is always useful even if it is someone else's.
[IMG] code is Off
