Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 11-22-2006, 08:26 PM
Dick L. is on a distinguished road
Dynapath System 10 keypad problem?
Hi! I've got a system 10 and the keypad is not recognizing keypresses from the letters S,W,M,D and the numbers 0 and 9. Has anyone seen this type of problem? I don't believe it is the actual keypad because I can get continuity between contacts on the ribbon cable from the keypad when pressing these keys. (ribbon cable disconnected and power off of course). Any thoughts?
Thanks!
[IMG] code is Off
