Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-26-2004, 11:01 PM
Gold Member
Ken_Shea is on a distinguished road
Is it good policy to remove anodizing from aluminum prior to milling or just have at it ?
Ken
Old 01-26-2004, 11:18 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Ken,
You come up with some good ones.
I usually machine my parts then send them out to be anodized, but hey what ever gets ya thru the night.
Your end mills won't even flinch when it comes to the anodizing. It's only a couple mils thick. Unless your are trying to just machine a very, very small amount off, .0003 or so, no big deal.
Old 01-26-2004, 11:28 PM
Gold Member
Well I am learning that in machining "Ignorance is not Bliss"
I had seemed to recall that anodizing was kinda tough on mills and drills in spite of it's very thin properties and wanted to double check.
Ken
Old 01-26-2004, 11:47 PM
bb99 is on a distinguished road
What about welding aluminum? Should it be removed?
--Alan
There are 10 types of people in this world; those that understand binary and those that don't.
Old 01-26-2004, 11:50 PM
Gold Member
I can answer that one, yes as it is non conductive.
Ken
Old 01-27-2004, 01:17 AM
motomitch1 is on a distinguished road
--Alan
Yes it should be removed alum. needs to be very clean to make a nice looking weld.
Old 01-27-2004, 01:25 AM
Originally posted by wms
Ken,
Sometimes you anodized first so it will have a cnc look, they do that all the time with R/C car parts
Old 01-27-2004, 03:06 AM
avsfan733 is on a distinguished road
the reason for cleaning aluminum welds is because the outer surface oxidizes very quickly, aluminum oxide melts at 3200 while aluminum melts at 1800 and boils at 2300 if i remember my numbers correctly...so if you don't clean it it can literally explode
[IMG] code is Off
