Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 10-18-2006, 05:29 AM
Kenworth18 is on a distinguished road
Unhappy Boxfords Again
Hi All,
I`ve recently purchased a pair of Boxford machining centres, a 165HMC and a 190VMC, and need assistance.The 165 is dead to the world apart from the carousel can jog ( safety interlock problem ?) and I really need a manual ( copy of? ) and schematic to help sort it out.A schematic for the 190 would also be appreciated.Anyone else own or have experience of the 165HMC as I understand that they weren`t produced in any great quantities? Both run from BBC computers at the moment but the plan is to upgrade to a PC and Mach3 software in the near future, after I`ve had a play!
Old 01-07-2009, 04:40 PM
BOXFORDCNCMAN's Avatar
BOXFORDCNCMAN is on a distinguished road
I came accross this post and so registered on this forum. If there is anyone out there who needs help with any of the old BBC driven Boxford CNC machines I can probably help, Manuals, Software, Controls etc. Specialist in the following:
BOXFORD 125TCL
BOXFORD 160TCL
BOXFORD 240TCL
BOXFORD 165HMC
BOXFORD 190VMC
BOXFORD 260VMC
GEC GEMINI DC Control
BRADFORD INSTRUMENTS 3 Axis Control
PARKER DIGIPLAN SD3 Stepper Control
Please get in touch if you need help with any of the above..
www.boxford-retro-cnc.co.uk
Cheers!
Andy
Old 02-22-2009, 10:17 AM
battwell is on a distinguished road
do you have any schematics of gemini dc control?
i have converted my 125 to mach. dc controller a bit slow to respoond!
Old 02-22-2009, 03:13 PM
Unfortunately not, Boxford didn't even have one. There is a "ramp" trimmer on the Gemini that should give you a degree of control to resolve this issue, have you tried it ?
Regards
Andy
Old 05-07-2009, 01:02 PM
george8013 is on a distinguished road
boxford 190 vmc
r
Originally Posted by BOXFORDCNCMAN View Post
BOXFORD 125TCL
BOXFORD 160TCL
BOXFORD 240TCL
BOXFORD 165HMC
BOXFORD 190VMC
BOXFORD 260VMC
Cheers!
Andy
Hi Andy I`ve just picked up 190vmc but without it`s bbc or any software,can you supply any info/software for this model.regards George
Old 05-07-2009, 05:34 PM
Hi George,
Are you sure your 190VMC is set up for control via a BBC? not many were.
If it is, it will have a blue 34 way ribbon connector cable for connection to the BBC 1Mhz Bus.
I can supply all the hardware and software to get this machine going.
drop me a mail at:
info@boxford-retro-cnc.co.uk
Cheers!
Andy
Old 05-28-2009, 04:59 AM
x3UK is on a distinguished road
Andy,
Have you either a pinout of the control/ribbon cable from the bradford control board to the membrane panel/LEDS or full circuit diagram please
Regards Peter
Old 05-30-2009, 04:19 AM
SimonD is on a distinguished road
Peter,
What machine do you have, I may be able to help with the schematic...
I need some info on the Gemini drive, if you have it. I need to know what pin 9 is connected to, I think it is an "enable" line but have no idea what to connect it to.
Simon
Old 07-24-2009, 05:31 PM
JohnViejo is on a distinguished road
Hello Andy,
I'm looking at a Boxford 190VMC that is going off sale by 6 pm GMT tomorrow.
No tooling; no computer; works manually, needs a bit of a cleanup. I see the company is still around. I'm wondering what I would need to have to get the machine fully operational. I've a computer, Mach3 software, Mach3 board, power supply, and drivers.
Any thoughts would be appreciated, such as what would I expect to pay for such a machine, keeping in mind the work to be done on it?
Thank you very much for your time and response,
John
Old 08-17-2009, 07:18 AM
MIKE CHADWICK is on a distinguished road
Hi In Uk most people swop the controllers for a 3-4 axis vi a guy called alex at www.eaziform.co.uk he does a far better stepper motor controller (micro type works with boxford stepper motors plus a proper cad cam program I had same problem as Boxford only sell to Colleges and universities and are no help with software Mike we want to use use as a mini cnc miller for making mototrcycle spares- in UK-
  #11   Ban this user!
Old 08-17-2009, 10:18 AM
Thanks for the feedback on Boxfords
Hello Mike, Thanks, I appreciate your insight -- that machine went through the auction and off to a new home. I've just this past week brought a large knee mill with Centroid controls into my shop. There's a problem with the X-axis encoder, apparently, and the Centroid people have been most helpful in sorting this out.
[IMG] code is Off
