Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-11-2004, 08:58 AM
mlinder's Avatar
mlinder is on a distinguished road
Is there one tool made for this?
I countersink parts all the time. However the attached file shows a countersink with an added recess area above it that I have never come across.
Do I have to use an endmill or flat drill first to create the .5mm deep recess, then countersink? Or is there a tool that will do it in one step?
Thanks for any and all input.
Mark Linder
Old 01-11-2004, 09:12 AM
duluthboat's Avatar
duluthboat is on a distinguished road
I'm away from the shop so I can't give you a source but its one tool. If we don’t have the proper size we grind one.
Gary
Old 01-11-2004, 11:42 AM
Bill is on a distinguished road
We do this alot here at work, as long as the ster is not to deep we grind the c-sink to size and go for it. If needs to be deeper we send out a endmill and have it ground.
Hope this helps, Bill Johansen
Old 01-11-2004, 11:44 AM
jeezz, I can not spell STEP
[IMG] code is Off
HELP Tool changer problems ddprecision Haas Mills 9 01-14-2011 05:24 PM
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 08:51 PM
Miniature Automatic Tool Changer 1ctoolfool Product Announcements & Manufacturer News 1 04-18-2005 06:56 AM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 09:56 AM
First tool for the tiny lathe (home made) pics Stevie General Metal Working Machines 5 05-02-2004 11:24 AM
