Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 09-28-2006, 07:36 PM
ncprecision is on a distinguished road
Question 401 servo alarm fanuc 6t
I have a 1982 Mazak Micro slant 15 with the fanuc 6t control. The Machine
constantly is getting the 401 servo alarm only when bringing the x axis down. The alarm seems to occur when the machine idles for 20 minutes or longer. I just had both servo motors rebuilt and replaced the pulse coder on the x axis. Sometime the machine will run great for a day or two then the alarm comes back. Anybody with any suggestions would be much appreciated.
Old 09-28-2006, 08:52 PM
Al_The_Man's Avatar
Hydraulic counter balance needs adjusting?
Old 09-29-2006, 08:06 AM
Thanks alot for the quick response. Is the hydraulic counter balance located
on the side of the servo? I see a small unit with hydraulic hoses running into it right next to the x axis servo motor.
thanks again
Shawn
Old 09-29-2006, 05:16 PM
Al_The_Man's Avatar
It is usually below the servo, there is a Mazak procedure to set pressure whilst running the X axis up & down.
Old 09-29-2006, 09:33 PM
Is the procedure something I can find in the maintainence manuals and do myself or is it something a tech needs to do?
Old 09-29-2006, 10:07 PM
Al_The_Man's Avatar
If you have the maintenance manuals it should be in there, I believe you just need a pressure gauge to read while adjusting the pressure.
Old 09-30-2006, 05:01 PM
Thanks for the info. I went to power up the machine and now it goes right into 401 servo before I even turn the hydraulics on. I opened the back door on the machine and noticed a red light (TGLS) lit up on what I believe is the servo amp board. The board is located on the other side of the velocity control. Would the TGLS light on pinpoint any one thing that could be wrong?
Thanks Again
Shawn
Old 09-30-2006, 05:21 PM
Al_The_Man's Avatar
Check the 3 phase into the drive and also check the overload reset.
Old 02-08-2009, 10:56 AM
akm36 is on a distinguished road
Sir,
I need the electrical wiring digram of Mazak make Micro Slant Turn 15 CNC Turning Center with Fanuc 6T. If some one has its machine manual and wiring diagram, pl. help me.
regards,
Mahajan
Old 04-25-2009, 05:25 AM
yours_prabhat is on a distinguished road
Originally Posted by akm36 View Post
Sir,
regards,
Mahajan
I can provide you the manual and electrical diagram for fanuc 6t my mail id is prabhatmishra@mail.com and contact number is +91-9430737981
[IMG] code is Off
