Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 09-13-2006, 12:16 AM
Masood is on a distinguished road
Takisawa CNC Lathe Communication Problem
Hello..
i am use Takisawa CNC Lathe
Model : TW-20
Date : 1996
Takisawa Fanuc
i am first time cnc lathe trying to connect to PC..Rs232, but it's not working
085 Cmmunication Alarm,
i am Useing Haas cnc milling machine connect to PC..Rs232, working is good..
i am trying to Haas cnc milling Rs232 Cable,and software, to Takisawa cnc lathe but it's not working good, 085 Alarm
kindly help me...
Masood
Old 09-13-2006, 02:56 PM
Al_The_Man's Avatar
List the contents of parameters
0002
0012
0050
0552
0553
What baud rate etc are set on the PC, is it set for software handshake?
Old 06-26-2011, 09:40 AM
cncsolutios is on a distinguished road
kindly check cable configuration and setting parameter on pc according to fanuc.
thanks
[IMG] code is Off
