Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 09-05-2006, 10:34 PM
Max Moreno is on a distinguished road
Exclamation OKUMA LC40 OSP5000L Communication problem
HELLO!
I have problems for upload and download part programs from PC to Okuma LC40 with OSP5000L control, I´ve tried with many different communication parameters configuration and cables but I can´t to transfer. Does anybody have some experience about?
Old 09-29-2006, 08:44 AM
broby's Avatar
broby is on a distinguished road
Hello Max,
I have a copy of a RS232 manual for Okuma's if you are interested.
Regards
Brian.
Old 08-21-2010, 01:13 PM
Burschulz is on a distinguished road
Hello Boby
can you send me the RS232 manual for Okuma's
thanks
Old 08-21-2010, 05:12 PM
broby's Avatar
As the file is slightly larger than the upload limit...
PM me your email address and I will send a copy to you.
Cheers
Brian.
Old 08-21-2010, 11:28 PM
jayhawk1963's Avatar
jayhawk1963 is on a distinguished road
Cool Okuma
You have to put a comma before every program when receaving at the machine.
Old 08-22-2010, 01:30 AM
broby's Avatar
Only true if you do not have the filename as the first line in the program.
i.e.
$YOUR-PROG-NAME.MIN%
If you do not have a program name, the machine will try to read in the file name as A.MIN (if all the parameters and cable is correct of course! )
If you can communicate, then using PIP ,FRED <write> will tell the machine to ignore any name at the start of file and name the file "FRED.MIN"
[IMG] code is Off
