| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Hi I wonder if anyone could advise me on connecting my laptop to a heidenhien tnc370 control for the aid of sending/recieving programmes? What type of cable would i need to put the rs-232 connectors on and were would i get it from? Your help would be very much appreciated cheers steve |
| Is it similar to other Heidenhain controls like TNC355 perhaps.? http://www.cadem.com/ncnet/dnc-detai...enhain-355.pdf Al.
| There two ways to comunicate with Heidenhain controls via RS-232. 1. ASCII download/upload No drip feed capability No error checking Requires PC operation Any terminal program works 2. Blockwise transfer Unlimited drip feed capability Line BCC error checking Use can use higher baudrates in safe way You can do everything from the CNC (copying, deleting, directory listing, etc.) Requires TNCServer.exe. Should be easy to find now. I payed de equivalent of 300USD to the Heidenhain Portuguese dealer for a diskette copyed in front of me (ilegal) in 1990. The null modem cable works great if you use software handshake (XON-XOFF). I am not up to date with the late models but I think they didn't change much regarding RS-232 operation. Also consider Ethernet operation. It's much faster... |
| Rousey goto www.heidenhain.co.uk and download TNCremote. Then goto the RS online at rswww.com (I think) and look for the at the pin out for a 9-25 way connector. the rest is easy. |
| Dear Rousey ! Hi! I see that you are going to thanks to all the people that made you some advis ! but this isnt advise ! the right answer is this below not the recommendation to other place ... i thinks for all of us better that we are not able to answer going to find the some qouestion that we are able to made answer ! ok! your cable for laptop Control system Heidenhain Time out (sec) 5 Control program start M82 Control program end M30 Is DNC required Yes DNC settings Port Number COM2 (or any free COM port) Baud rate 2400up to more as you need ! Data bits 7 Parity Even Stop bits 2 Handshake Hardware Filter null characters Yes Transmit settings Transmit directory Specify folder to store programs to be sent to machine from PC Wait period at start of transmission 10.00 Wait period after transmitting program 5.0 Delay period after each string 0 Wait for XON before transmitting program No Server mode Off Comment start character ( Comment end character ) Program start string ^2^ Program end string ^3^ Receive settings Receive directory Specify folder to store programs coming from machine Wait period before receiving program 45.0 Wait period after receiving program 5.0 Transmit XON before transmitting program No Reports and errors Transmit descriptive messages Report / Error message start Report / Error message end Ignore control characters other than CR-LF Yes Null modem cable, with full handshake PC, 9pin, DB9M CNC, 25pin, DB25 2-----------2 3-----------3 4-----------6 5-----------7 6-----------20 7-----------5 8-----------4 this full ahandshake! F. |
| F. Sharifi mate I have no problems with what you suggest but I didn't realise that this was the forum for the IEEE ! There is free software available from the website I mentioned that does everything required to talk to a Heidenhain control. My omission of a cable pin out was the flaw in the post but to say the advise before yours is unfair. I have worked on Heidenhain controls among others as a tech for 12 years and to be honest what on earth is your post about? |
