Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 08-21-2006, 10:54 AM
raymon is on a distinguished road
looking for send program to cnc;
I am looking for a simple program that works in Dos.
I want to start the program using stanandard bath (*.bat) file .
for example if i want to send file named 'test.txt' to the cnc ,all I need to do
Is to write in the Dos prompt cammand line : send test.txt.
The reason I am looking for such program is ,I have another g-code program
That was Writen specially for our machine and I want to combine both
programs in one bath file so I can make the file and send it using one dos
command.
I am thankfull for any one that can help out.
Old 08-21-2006, 01:08 PM
Al_The_Man's Avatar
I am not sure how you intend 'merging'? two files to send?
You may be able to do in in one of the modem programs that run under DOS using a Script file.
I have used both Qmodem and Telix for general communication, they are still both available in shareware, if not I have a copy if you need.
I have not used script files really, but there is a copy of the Qmodem program Manual.
You may be able to work it out.
The PDF screwed up the formatting a bit.
The file was to big to upload so I just show the scripts detail, remember the program was originally intended for phone modem so there is alot you can ignore.
It works fine in direct RS232 mode.
Depending on what you actually want to achieve there also may be a way to just use simple DOS commands in a BAT file and use 'TYPE' directed to the COM1: port instead of the screen.
You would have to use a program that sets up the right conditions on the com port, however.
Old 08-22-2006, 08:38 AM
First I would like to thank you for your help.
I would appresiate I you could send me the files you mentioned.
thanks
Old 08-22-2006, 09:36 AM
Al_The_Man's Avatar
Send me a PM with an email address I can mail attachments to.
Old 08-22-2006, 10:35 AM
psevin is on a distinguished road
You may need nothing
Depending on your version of DOS, you may be able to use the MODE and PRINT commands to do this. For example -
mode lpt1:=com1 (re-direct printer port to com1 port)
mode com1:9600, n, 8, 1 (set com1 parameters)
print test.txt (send file out com1)
Paul Sevin - Ovation Engineering, Inc.
http://www.ovationengineering.com
[IMG] code is Off
