| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
| I'm running a small carving machine(home built) using a 3 axis controller from http://www.stepper3.com/31.htm. Up until today the unit seemed to be operating just fine. With some loss in stepps. My motors are 6v/1.2amp unipolar types. I'm using a standard 12v supply with 1 ohm resistors on the power legs. I was just informed that the correct resistor to use should be a 3 ohm for this setup??? (12v psu)-(6vdc motor) ------------------------------ = 3 ohm resistor, 2 amp current What I found after playing around a little today was, one of the motors had basically no toque. Could I have burnt this motor? How much current would be to much? Neil |
| Where does the resistance of the windings enter into your calculation. I'm a noob at this stuff, but is it correct that that the resistance of your windings would be 5 ohms? That would make a total of 8 ohms, then, which would allow only 1.5 amps to flow. (Shrug) Maybe Balsaman could answer this, he's a real smartie at this stuff, amongst others (no offense meant to others )
| Here is the steppercalc screen shot: It indicates you need 4.25 ohm resistors. 4 would probably be fine (1.23 amps at the motor). Your 1 amp resistors make the motors draw 1.85 amps each. That is plenty high. Were they getting very hot? Eric
__________________ I wish it wouldn't crash. |
Great avatar you have there Thuffner3, I don't know if you are familiar with that character, but earlyer this year that albino Gorilla passed away in Barcelona, after illness. Nah...You probably heard that allready somewhere else. I thought you might wanna know if you were unaware of this. Good luck with your project, yes i noticed that too ![]() Ed'.
__________________ Not the horse, of course of course... Building my own Scrapheap challenge CNC, or is it Junkyard wars CNC? |
| bad stepper | PapaJohn | Stepper Motors and Drives | 0 | 03-15-2005 11:17 PM |
| Not good for a stepper motor? | FLUTE HEAD | Stepper Motors and Drives | 4 | 12-02-2004 12:31 AM |
| Fun with floppy stepper and driver | Konstantin | General Electronics Discussion | 5 | 03-08-2004 02:18 AM |
| how do i determine what size stepper motors to use? | capitalv | General Electronics Discussion | 3 | 01-20-2004 03:22 PM |
| disassembly of stepper motors | dhprc2 | General Electronics Discussion | 8 | 06-25-2003 08:09 PM |
