Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 07-31-2006, 04:02 PM
Tim Montzka is on a distinguished road
Erratic step signal?
I am using a Sure Survo AC servo controler from Automation Direct with CNCZeus and an old DOS PC for my pulse and direction signal. When the comand is to move positive x direction it is fine, but to the negative x I get totally erratic responses. If I use the PC's jog function it will move way too far to the left and not move smoothly, if I have it execute a program it is also way off. The Sure Survo's jog function works just fine. I have also hooked this computor up to my old Gecko Drive controlled system and it works fine. Any ideas?? I am totally stumped.
Can anyone help me with how a direction high or low from my PC might affect the step signal?
[IMG] code is Off
