Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
  #13   Ban this user!
Old 11-30-2003, 11:31 PM
cwww is on a distinguished road
The inside of my motor looks like this, which is a little bit different from the pic in the maintenance manual. I wonder if I need to remove the black cover or not, in order to rotate the resolver. BTW do all these things meant to be done when the power is still on? Seems that there're quite some cables around the resolver...
  #14   Ban this user!
Old 12-01-2003, 12:08 AM
motomitch1 is on a distinguished road
If you can't turn the resolver ,cold start vmc,loosin the coupler were it connects to the ball screw or servo motor. You may have to pre loosin the coupler so it can be rotated to were you can get at the screws and then turn the ball screw till your cold start lines - lines up. while the servo is on and in proper position and since you loosin both screws up on the coupler you should be able to spin the coupler around were you can get at the screws and tighten them up. There could be some safety issues but thats how I would do it. I would just be real carefull.
  #15   Ban this user!
Old 12-01-2003, 12:14 AM
That looks like the newer ac servo my work has older Fadals with dc motors
  #16   Ban this user!
Old 12-01-2003, 11:03 PM
cwww
Anyway, I think my motor is bad, cos since I swapped the one for y-axis with the one for z-axis, my z-axis started to have problems...
  #17   Ban this user!
Old 12-01-2003, 11:07 PM
hardmill's Avatar
hardmill is on a distinguished road
Have you tried just swapping the encoder only and not the
whole motor?
Just a thought.
PEACE
[IMG] code is Off
Beginner Troubleshooting and Building Considerations coherent FAQ of CNC Machine building 3 11-10-2011 01:27 PM
4th Axis for Fadal 4020 Fudd Fadal 12 01-27-2009 05:43 PM
Series 2 BOSS 6 Axis motion problem craig96us Bridgeport and Hardinge Mills 43 01-14-2006 11:06 AM
How To; troubleshoot an Axis problem on Bridgeport BOSS inthedark Bridgeport and Hardinge Mills 0 03-25-2004 07:35 AM
MP32 fadal controller problem nervis1 Machine Problems, Solutions , Wireless DNC, serial port 0 02-01-2004 01:27 PM
