| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
| Mazak pausing This one is strange, but when I use a G51 (through spindle coolant) code on my M Plus control in any of my programs, EIA or Mazatrol the machine has a long pause when it reads the G9 to turn the through spindle coolant off. Any ideas??????? |
| where is the valve in relation to the coolant head, could it just be whatever is left in the lines coming out from between thevalve and the head? |
| The coolant shuts off right away, but the machine sits with the spindle running and "pauses" before exicuting the next comands, whatever they may be. |
| Could it be possible that the pause is written into the PLC ladder logic for some reason? Is the spindle coolant pressure monitored on your machine? Perhaps a sticky pressure switch is slow to open? Perhaps a relay or contactor is sticking due to arced over contacts?
| Do you really mean G9 or is it M9. G9 is exact stop on most controls (industry standard) |
| That's a good call, Mortek. That would make sense, as coolant function is generally not a gcode. I can't figure out, though, why the coolant would be shutting off and the machine doing an exact stop check at the same time, from one code.
| I dont know why I said G51 and G9 when I meant to say M51 and M9. Must of been one of those days. |
| You may be right with the idea of pauses writen into the PLC. I do know with Mazak they do things a bit different for some reason. You woun't belive how hard it was to set up communication with the machine. In most cases you would set the DL softwear to the same parameters as the machine, but with Mazak the control and DL softwear are both set to different parameters in order to work. Thanks for your help Dan |
| I used to call Mazak in LA , They probably can help you with a parameter to solved this. |
| Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1' | Haaatschi | Machine Problems, Solutions , Wireless DNC, serial port | 20 | 08-22-2010 01:55 AM |
| Mazak 8G M/C,mazatrol eia-t, z axis stuck | imwllc | Mazak, Mitsubishi, Mazatrol | 7 | 09-07-2009 11:48 AM |
| Mazak Rotary Turret Switch reBuild | Al_The_Man | Product Announcements & Manufacturer News | 6 | 04-11-2007 11:21 AM |
| Probing - Mazak Fusion | CFisher | Digitizing and Laser Digitizing | 1 | 06-08-2005 12:02 AM |
| Mazak L Alarm | SFA | Machine Problems, Solutions , Wireless DNC, serial port | 2 | 05-26-2005 01:52 AM |
