Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 11-14-2003, 06:37 PM
harley88 is on a distinguished road
Ez-path Lathe
I UPDATED THE SOFTWARE ON A 1995 EZ-PATH LATHE AND NOW I'M GETTING A LOW LUBE ALARM EVERY 30 MINUTES.I NEED TO GET TO THE PARAMETER PAGE ,TO CHANGE THE SETTING FOR THE OILER.CAN ANYBODY HELP? THANKS
Old 11-14-2003, 08:57 PM
duluthboat's Avatar
duluthboat is on a distinguished road
harley,
It’s been a while, but if you hit the reset button, as the screen comes on there should be a message at the bottom of the screen, “Del for setup”. Hit the Del button and your in. That’s as far as I can go. If you only have a number pad, you may need to plug in a key board to navigate in the setup pages.
Gary
Old 05-26-2008, 02:55 AM
Bluey is on a distinguished road
harley 88, i have an ez path, same one, the 2 wires to the sensor on the lube unit, if you disconnect these, and bridge them with a wire, you wont get the lube alarm at all, this is great because if your half way thru a thread, it wont alarm and cut off on u, just make sure u regularly check ur lube levels. have had this machine for 6 years and would never get rid of her. im in australia and only a handfull came here, if i could get another i would.
[IMG] code is Off
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 01:06 AM
Help me buy my first Mini Lathe Highfly Mini Lathe 20 05-10-2005 03:07 AM
OneCNC XR Series Lathe CAD/CAM Released: OneCNC Product Announcements & Manufacturer News 0 03-07-2005 05:20 PM
Just got a taig lathe. anoel Mini Lathe 2 01-18-2005 05:29 AM
Mastercam lathe crash course CNCnUtZ Mastercam 6 09-26-2003 02:03 AM
