Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-14-2006, 08:09 AM
harvard5 is on a distinguished road
Crusader II tool offsets
I have a Crusader II that will some times work with the tool lenght offsets (TLO) and sometimes it wont. I have tried the examples in the manual and they work except the TLO dosen't always work when you call up a tool number or when you try to cancel a TLO. Could it be a bad chip and if it is how do I find it?
thanks Bill
Old 03-14-2006, 02:11 PM
logos is on a distinguished road
There has to be 2.5 times the radius tool of movement in proper axis before the comp will turn on.
Old 03-14-2006, 06:07 PM
brianaldrich is on a distinguished road
cursader2 as in anilam if so i was a anilam tech this a mill or lathe
Old 04-13-2006, 02:57 PM
Mike Mattera's Avatar
Gold Member
Mike Mattera is on a distinguished road
I've seen people try to set the offset, when an offset is already active. Make sure to do a Tool 0 command before you touch off the tool. Otherwise the number in the display will be off.
Mike Mattera
Crusader 2 Training DVDs available at our web site.
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
[IMG] code is Off
