Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-10-2006, 02:28 AM
Ninus is on a distinguished road
Question DNC between FANUC 16 and CIMCO dnc Max
Hello.
I'm getting problems with the remote request function.
It seems that Fanuc control is not sending DC1 when we push the start button in Tape Mode.
Has somebody experience with this matter
Old 02-10-2006, 09:03 AM
Dan Fritz is on a distinguished road
DC codes in Fanuc 16
First check to see what I/O channel you're using. If you press the Setting/Offset button, you'll see a setting marked simply "I/O". This number is usually set to "0", but it can be set to "1", or "2" for other serial port channels, or "3" for the Fanuc Remote Buffer.
If the setting is "0", look in parameter 102
If the setting is "1", look in parameter 112
If the setting is "2", look in parameter 122
If the setting is "3", look in parameter 132
If the setting is "4", your set up to use the SRAM card slot next to your CRT.
The parameters listed above are normally set to "0", which is a setting from a chart in the Fanuc operator's manual. A setting of "0" means that a standard RS232 protocol with DC codes is used. Other settings are intended for Fanuc devices like the Fanuc Cassette adapter, the Fanuc portable tape reader, etc.
Old 02-10-2006, 10:03 AM
Sorry, make mistake.
The cnc is a Fanuc 15 and de I/O device is 0 and in the parameter 102 device number=0. So I think the settings for the standar RS232 has to be in another parameter
Ninus
Old 02-10-2006, 10:07 AM
Wrong CNC
The Fanuc 15 uses parameters 5110, 5120, and 5130 to set the communicatons protocol. I recommend that you set "3" in all three of these parameters.
Old 02-10-2006, 10:29 AM
Thanks Dan, next monday i'll tell you how it works
Thanks again
Old 02-13-2006, 09:32 AM
Ok, Dan.
It works correctly. Handsnake or Xon/Xoff is redy now.
The only problem that I have is that I need an Xon character when I push the start button in tape mode and it depends of the maker of the machine, in that case is a Mori Seiki machine and I can't detect this character.
Any way I introduce an delay in to the pc so I have enough time to change to Tape mode push the start program and wait while the program comes
Thanks again.
Ninus
[IMG] code is Off
