Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-03-2006, 05:53 AM
JohnAn is on a distinguished road
Electrical Motor Noise Sherline Mill
I am new to te world of CNC.
Purchased a Sherline Mill and Servo and controller system.
There seems to be a problem with noise the DC motor is producing when operating at top speed. Servo's lose position or controller issues an error message.
Have shielded leads etc and still problem. Has anyone solved this problem and if so how?
Old 01-03-2006, 07:37 AM
Al_The_Man's Avatar
What makes you think it is noise? Make sure the encoders are not run with the DC motor armature leads and also to minimize EMI, the motor leads should be run tightly twisted and also shielded if possible.
Old 01-03-2006, 08:33 AM
Gold Member
imserv is on a distinguished road
If you are using the DeskCNC servos, it is not necessary to shield the motor power cables. You do need to take some care with the encoder cables.
A description of the 12 foot cables we use on our Sherline servo systems:
"These cables are 100% tested and certified to accurately transmit, quadrature encoder pulses at speeds up to 85,000 steps per second. "
Fred Smith - IMService
http://www.cadcamcadcam.com/hobby
[IMG] code is Off
